Looking for epoxy floor installer in MD
ajn507
Does anyone have a recommendation for an epoxy floor installer in MD?
I live in Towson and just built a 30x30 garage and looking to get it done ASAP.
Thanks
Alan
thammel
Maryland
Can't help as I did my own with Armorpoxy myself. I'm in northern Baltimore county and lived in Towson for many years. This is not a good time of year to do the floor. I did mine this past September. Good luck finding someone....try Angie's list??
Tom
A
ajn507
Tom
Tom,
Do you think that even if I run a heater before the install it would be an issue?
How big of a garage did you use the Armorpoxy on ?
Did you run into any problems? Would you do it again or do you think you would have someone else install it?
thammel
Maryland
Tom,
Garage is 28x32. No problems. I would definitely do it again! I posted a bunch of details after doing it that would probably help you a lot. Check them out. The main reason to do it in better weather is that you usually need a place (driveway) to set up, mix, move to when done. This is in addition to just being comfortable, being able to use a hose to clean up, etc. I say just be patient and wait for the Spring. I’ll be glad to give more advice and tips.
ford fanatic
Darlington, Md
I'm in northern Harford County...
I got estimates from here http://www.prestigefloorcoating.com/ and one other place last year (30' X 40' garage). Their prices were thousands of dollars apart, and they both prepped the same. I denied both companies and installed Armopoxy myself because of the expense.
I will say that both dropped their price some after I turned down their offers, the one place called months later offering me like 50% off because he was slow at the time.
