Looking for ideas for gear holder
MikeC55
CT
I'm disassembling a Subaru 5 Speed (manual) transmission and have run into a problem of holding on the one of the angle tooth gears in order to remove a retainer nut. I have attached a diagram from shop manual showing special tool (ST1) in a vice (tool isn't available, even if I wanted to spend the money). I tried just clamping the gear tight on the (flat) aluminum jaw covers and there just too much torque involved on the nut to hold it. I need something that can mesh with the angle cut teeth.... Ideas?
LXCam
Making a version of that tool would be fairly easy. Get a block of aluminum, bore a matching hole and cut it in half.
Marsim
Cut the end off an appropriate sized socket then cut it in half and use it as a sleeve for the vice?
MikeC55
CT
Thanks guys, I'm going to try the wood first. I would think a standard 2x4 might do the trick if jaws are wide enough. Might have to use 1 x . I was also thinking of welding/filing some simulated gear teeth on steel plate to put in the vice. But wood would sure be easier. I may need to get a stronger impact wrench too. Mine wasn't doing it before the gear slipped out of vise. I suppose a chunk of aluminum bored to OD of gear diameter and cut in half might work, but I have no easy way of boring a hole that large (maybe a hole saw, but I think the ones I have a for wood).
2oolhound
BC Canada
Most bimetal hole saws cut steel just fine. Aluminum should not be a problem but I like the wood idea best.
duneslider
Riverton, Utah
I also think you will have more success with a big impact than a wrench and socket, the leverage with a hard pull on a long wrench will make it want to slip much faster than an impact will.
Instead of wood, maybe an old Delrin cutting board, otherwise the same, consider it 1x material, may need two layers to make it work
