looking to put this down
Scottishross
were can i get it plus can u do it yourself what works needed
Garage Flooring
Grand Junction, CO
This looks like an epoxy floor in the typical Tuxedo look with a top coat, hopefully and aliphatic urethane. A base layer of epoxy is installed, full broadcast of chips, the loose ones are then removed and then a top coat is applied (way simplified)
I would private message Legacy industrial or I believe it is DCS about pricing and availability. They have a lot of knowledge, can walk you through the prep and you will have an outstanding floor. JUST TAKE YOUR TIME AND DO IT RIGHT
Scottishross
i know its a US thing but i really like it its just the money since its a big area
any info would be good
LegacyIndustrial
deerfield, IL
As Justin mentioned...
Prep as require, Primer Coat and allow to cure, Base Coat and broadcast chips to rejection.
Next day, knock down any high flake with a squeegee and vac off the loose flakes.
Add a top coat of clear polyaspartic or urethane.
Figure 5-7 sq ft per pound of flake.
