GarageGuy89
Currently have the HF special 90 amp flux core. Which does fine with the thicker miscellaneous fixes I've had to do over the years. However, anything thin enough to bend with your hands seems to burn right through the metal, and impossible to weld.
I've had a couple projects lately that have required welding the thinner stuff, but then again being a weekend grease monkey, I only pull the welder out less then 10 times a year, so I don't use it a ton.
Ideally, need something full range that can weld thin sheet metal, as well us anything up to 1/4 or 3/8 being the thickest. As I said earlier, don't do a ton of this welding but I have found I need a more versatile machine, without breaking the bank.
Hopefully you guys understand where I am at with this, was hoping I could get some suggestions on welders to look for on craigslist without breaking the bank. I'd say the bank is no more then $500 at this time.
Thanks!
(EDIT: A 220v outlet is available for this)
Thanks!
