low voltage DC wire polarity coding
The Cobbler
I've got a roll of old time speaker wire or low voltage I guess is more appropriate.it's about 22AWG stranded
the sheath is not marked in any way, but the strands are pure copper colour & copper with a silver twist in them.
I seem to be getting conflicting info on Google as to which is intended for + & which is intended for -.
I doesn't really matter I suppose as this is all going to be soldered up. I just would like to keep it correct.
Thanks
BurtEggley
solid copper is positive. Tinned is negative. That is how we did it in an audio shop years ago. White strip or ribbed when present is negative. Sometimes you will find a roll of speaker wire where one lead is fully tinned and the other is copper. The copper looks red compared to the tinned wire. Think of it that way - red is positive, making tinned negative.
T
The Cobbler
thanks guys! I was heading that way but just wanted some reassurance . here's the project, Tire of replacing the batteries in the clock at the warehouse.
yeah, maybe I have too much time on my hands! LOL
added a buck transformer to a 6Vdc wall-wart and ran it to the clock
PCustoms
VT
It really doesn't matter, as long as you're consistent within a run, but I've always used copper=red=positive
T
The Cobbler
and when the power goes out
in about 4 yrs the power has never gone out for more than a few seconds, other than maybe 3 times where it's been off long enough to have to set a clock. I get notified from the alarm co that the power is off & again reinstated .
it seems like every 3 months I have to climb up & change them ... realistically it's not that often but I thought I'd give this a try .
T
The Cobbler
Wal warts seem to have white striped as positive. ( based on 2 that I worked with today...
as per google
In most DC electronics (like wall adapters and small electronics), the wire with the white stripe or dashed line is positive (+), and the solid black wire is negative (-). However, this is not universal; always use a multimeter to verify polarity, especially in RV or specific audio applications where conventions may differ.
Electrical Engineering Stack Exchange +3
General Rules for White Stripe Polarity:
  • DC Power Adapters: The striped wire is generally positive (+).
  • Speaker Wire: The wire with the stripe or ridge is usually positive (+).
  • Alternative Convention (Sometimes): In some specific systems, the solid color is positive, and the striped wire is negative.
  • Best Practice: Use a multimeter to check the output, as color coding can vary by manufacturer
pancho400cid
Austin, TX
I just went through the same issues.
Short answer is it absolutely makes no difference electrically as long as you are consistent.
The general convention is:
Positive/red/copper
Negative/black/silver
