Machinery floor
Nelson58
New York, New York
I like the interlocking tiles like they have on garageflooring.com, but I have wheels on a 1000 pound lathe, and 1800 pound mill, and wonder if I can have those tiles under these machines and be able to roll them, and also if the wheels/casters won't put deep dents in them.
matt_i
My thoughts are no, if your caster has a 1" square contact patch which is an oversized estimate you are pushing 500psi.
Try to take a thick tie wrap set on the concrete and roll your loaded caster over that...I think it will be a big issue.
NUTTSGT
Northern Central Ohio
But if I need to roll them onto the floor tiles, it will be hard to do.
I'm curious as to why you would need to move them ? Once in a great while to change something or rearrange the shop, yeah I could see that. For the once in a few year move, just pull the tile up and replace.
turfgnome
My Mill is light at around 600lbs and the lathe I own is just slightly more but I would not move either of them unless I had no other option. And my 2000 lb drill press and surface grinder will likely not moved again while I am alive. To put that in perspective I turn 40 next year.
N
Nelson58
New York, New York
They won't move much, but I have a tiny shop of only 8x12 or so. Might need to move things around a little to set them up.
I'm looking for some very hard plastic or polyprop interlocking tiles that can stand up to the weights of a lathe (1000) or mill (600).
slodat
Central-ish, WA
I got quotes from Lock-Tile and Flexi-Tile last week. At 1300sq ft, Flexi-Tile was about $300 less. Both companies said the others product was basically the same thing. I plan to order from Flexi-Tile. Have them quote it, the price was significantly better than their website.
Tutt
I have machinery in my garage and would love to do plastic tiles, but i have 2 major concerns.
1. The chips off a lathe are freaking hot. I would imagine that they would melt into the floor.
2. My garage faces west and I am worried that with heavy machinery preventing the floor from moving on both sides, i will have problems with the floor expanding and buckling.
Anyone have real wold experience with this? I sure would love to go this route.
N
Nelson58
New York, New York
Email us for a quote on our www.supratile.com. We may be able to save you some money depending on the tile you want. Our tiles are rated for forklift duty since they are solid. We park 80,000 lb fire engines on them (www.armor-tuff.com)
Thanks!
Tried but it came back:
Your message cannot be delivered to the following recipients:
*@#$ Recipient address: **[email protected]
I need 100 square feet of the dark gray diamond for my small shop.
Armorpoxy
Please call our office tomorrow or resend email. Many thanks!
