Matco - OTC tools
swgray
maryland
I recently came across a lot of Matco and IR tools. Some OTC also. I've got quite a few ratchet and air ratchet repair kits, haven't catalogued it all yet. If you have a need and know the part number, let me know. I'll see if I have it. Photobucket isn't cooperating this evening or I'd have more pictures. Shipping is included and will be adjusted accordingly for multiple purchases.
Matco MST9740A includes 2 pushrods. There is a third I'll include with it, but I'm not sure if it a correct addition to the puller. This can be upgraded to the newer "MST9740-C" with the purchase of MST6491. $50
Sold, paid and shipped.
Streamlight Stinger Flashlight Charger Holder 75100 $10
Streamlight Charger Holder Stinger (10 hour) 75100 is an accessory for Streamlight Stinger Flashlight. Streamlight Stinger Charger Holder fits all Stingers: Stinger, PolyStinger, Stinger XT, Stinger XT HP, Ultra Stinger. Streamlight Stinger 10-hour Charging Holders do not include cords. 12-15VDC
OTC 212635 Chrysler Adapter Cable For OTC Scan Tools $12
Standard 12' adapter cable for Chrysler: '84-'95.
OTC 7917 Live Center Forcing Screw Plug $8
This plug replaces the existing forcing screw on the 7248 C-frame to allow its use on heavy-duty ball joints.
The 7917's shorter length gives the c-frame a wider opening to accommodate the larger ball joints on 3/4 and 1 ton trucks.
OTC 6145 - Tamper Resistant Torx - Bits and Socket Holder Set - 8 Pc $9
OTC's Bulletproof Torx sockets are made from superior S2 steel.
Set includes: 1/4" sq. drive socket x 1/4" Hex holder, T10H, T15H, T20H, T25H, T27H, T30H, T40H.
Matco Tools AN-1930 Locknut Bearing Tubular Spanner,
Wrench 2 7/8”, $22
Six lug, spanner type wrench. Removes & installs rear wheel bearing locknuts. 3/4" square drive opening. Socket O.D. 2 7/8"
Services 1954 to current Chevrolet & GMC 11,000 & 13,500 lb. axles.
Matco Tools AN-1931 Locknut Bearing Tubular Spanner,
Wrench 3 5/8", $28
Six lug, spanner-wrench is used to remove and install rear wheel bearing locknuts. 3/4" square drive opening. Socket O.D. is 3-5/8"
Used for servicing Chevrolet and GMC 15,000 lb axles ; 17,000 lb 2- speed axles; 15,000 lb trailing axles
OTC 6921 - Wheel Bearing Locknut Socket - 2-1/2 $11
This 2-1/2" socket fits hex nuts found on rear axles and various front axle applications on light-duty trucks. 1/2" square drive.
jshillin
PA
Could I get a pic of: Matco MST9740A ??? I see you said photobucket is having issues, if you need to email it, PM me and I'll give you my email address.
Thanks
swgray
maryland
Do you take paypal? If so I'm ineterested in OTC 6145 and 7197 shipped to 92584.
Yes, Paypal preferred. Sorry, forgot to mention that. For those 2 items I'll make $15 total. PM me and I'll send you my e mail address for Paypal.
swgray
maryland
Thanks to jshillin and scrapmetal. Your payments were received and tools were shipped.
Anybody else want some?
