kool
Hey guys,
Slowly putting my lift together and running. Installed the anchors today.
-Drilled 5/8" pilot hole. 2" deep.
-Drilled 7/8" finish hole. x10
-Slab is 5" thick.
-Drove the anchors into below concrete surface as in instruction book.
-Positioned the posts and torqued to 80 ft.lbs. each.
-Removed the bolts to look at anchors, all are still below concrete surface.
-Shimmed accordingly for plumb and re-torqued.
Now my question is......what did you guys torque these bolts to?
I don't plan to move the lift after torqued.
Will post pics when I get there.
Thanks.
-Slab is 5" thick.
Thanks.
