Miller 211 argon hose
90zcar
I need a new hose for my older style miller 211 mug welder. All the ones I look up have 2 hose ends that look the same. I'm looking for one like this
Cope
Houston, TX
Just find one with the same tank end, which is standard. You can cut off whatever is on the other end and use the flow gauge end you already have. Should be plenty on eBay if you don't have a local source.
laser3kw
northen IL
like Cope mentioned, if you remove the spring clamp, you can pull the fitting out of the hose. It is most likely a barb fitting. I believe it acts as a restrictor for the flow gauge. Do not alter it. Then get any standard inter hose and cut one end off and insert the ******.
PCustoms
VT
Remove the ring on one end, save fitting.
Cut the brass crimp from the other end with dremel or side cutting pliers. Save the fitting.
Got to hardware store and get $5 worth of braided hose and 2 hose clamps. Attach saved fittings to new hose using new clamps.
Spend the money you just saved on something nice.
90zcar
Good deal thanks guys. I knew the end with the spring clamp was removable. Just didn't know I could cut the other end.
