Diesel Dan
Here are my mini split leaks.
Both evaporator coil leaks, no flare issues.
The first one has a small pin hole that had been getting topped off for some time now, paid $$ for a "professional company" that couldn't find the leak. After I got fed up and system leaked down again I put 400psi of nitrogen on it and started checking flares, because that is what most complain of. Upon pulling the squirrel cage out to check those flares I found an oil sheen in the drain pan and an oil spot in the middle of that evap core. Replaced, recharged and working great. Just over month later, unit 2 stops blowing cold. Of course, it was holiday weekend and wife recently had knee replacement so had to top that off until I could source another coil. That one was a massive leak at an evaporator tube end solder joint.
Details:
Fujitsu 18k dual zone condensing units. One unit runs 7k & 9k wall units. Second unit runs a 9k wall and 9k cassette. Both installed summer '17.
Mitch says, 2 outta 3 times but I have to wonder when/if #3 checks out.
OEM cores no longer available because 410a.
Details:
