Mini split lines - too collapsed?
RipSnort
I was bending my mini-split lines and one of them is partially collapsed. unbent OD =0.37 in. Partial collapse OD = 0.25in. Is this too much? Should I cut it off and reflare the cut end? I would need to order that tool. Any suggestions appreciated.tube collapse.jpg
Jackfre
N CA
It is so easy to flatten these lines. Some I have installed, if the lay-out allows, I strip the insulation off the tubing, put a spring bender on the pipe and shape sliding the bender along the line. Gives pristine shapes and concentric line sets. Slide the insulation back over the pipe and you are good. Well, as long as your flares are just right. Justin, what flaring tool do you use?
justinjoyal
Quebec
Yellow Jacket 60295
