Good afternoon. I have a Modine Hot Dawg 75AH0134 that is around 20 years old, that has never given us any problems, until recently. When there is a call for heat, the unit will go through its start up cycle, including energizing the heating element. No gas is released from the valve. The unit will cycle 5 times and then go into lockout. The valve will flash 6 times, indicating a lockout. The 2 rollout switches and the limit switches all are closed, showing 14 ish volts across them. I watched the low side of the transformer and see about 25 - 26 volts to the circuit board. The low side voltage is steady. The pressure switch also shows 14 volts. I expect 24 volts. I replaced the circuit board and have the same problem. I unplugged and jumped around the limit and roll outs. The venting is wide open. It’s hard to confirm, but I can only assume that the new board is transferring 24 volts to the valve. Also, I did purge the gas line, for fun.
Has anyone ran into this issue? After chasing the usual suspects, I’m now suspicious of the gas valve.
Thanks
Thanks
