More lighting advice.
NXGTS
Indiana
Just starting the process of my build but the local big box has what seams to be a good sale on lights right now. Menards has in their ad "commercial grade" wraparounds for 29.99. 1: Are these any good? They are 4' and require 2 32W T8 lamps. 2: I really need help as far as quantity.
My garage is a 30 x 48 split into 2 sections. The front half is the entry and will have a 10' 8" ceiling. It is 30' x 22' deep. I was thinking 3 rows of 3 lights per row. Does this sound like it will be about right or is that to much/ not enough lighting? This section will be used for a wash bay and occasional woodworking.
The back half of the garage will be 30'W x 23' deep. The two sections are somewhat devided by a stairway in the middle. That is why I am missing 3' from the two sections. Anyway, the back area will have a 4 post lift and a social area for the guys as well as a restroom in one corner. It will also have scissor trusses so vaulted ceiling. This is where I get real confused. Any idea on how many or what kind of arrangement to take here?
ibedayank
Columbia TN
JMHO... wood working needs LOTS of light i would run 2 circuits of lights spaced every other light is the other circuit. that way when you need more light just flip the others on.
tig
Durango, CO
In my opinion you can not have too much light. One of the biggest mistakes I made on my garage was not having enough fixtures installed. I had to have additional fixtures added later and I'm STILL not happy.
I've even removed the plastic covers to reduce diffusion.
I have to use portable halogen units when I'm doing detail work. I'll probably have my electrician out again to install more sometime...
