mortorq???? Anyone use it
90zcar
Just curious if anyone uses these fasteners? And for what? Should I add these to my list of weird fasteners?
90zcar
It's an iPhone......what do you expect
xj31
2015 Jeep Grand Cherokee seat belts and GM bellhousing to case bolts.
Grand Cherokee ? That's news to me. The KL body Cherokees use them on the bolts that hold the seats, not the seat belts. 200 also. :dunno::dunno::dunno:
Skin
Boston
Goddammit, who do we gotta kill to get the stupid automotive engineers to stop making up silly new fasteners? :mad:
Mortorq is from Phillips, not automotive engineers, its also been around for some years now. It was designed as a high strength replacement to phillips for similar fasteners like pan head, countersunk, and low profile cap screws. I don't mind advancements and its welcomed in the rust belt, the issue I have is how slow to adopt manufacturers are so that these tools collect dust 98% of the time.
DSLTRK
PHELAN, CA
Does Mortorq hold better in the tightening direction than in the removal direction? That is,wallow out or cam out easily upon an attempt at removal? If so that is not good,and another fastener would be better from an engineering standpoint.
I would think so, since it is not a tapered drive system such as Phillips. I don't think "Mortorq" would be the trademark if it did cam out easily.
Smokeshow69
Yeah, the Dodge Darts also use them. Apparently the fasteners cut down on the assembly time at the factory. They use them on the seat to floor pan mounting holes. Pretty dumb if you ask me. How many more fasteners types in the world do we need?
uart
Australia
I think Wakefield's point (and one that was wondering as well), is why the asymmetrical design. I mean that thing just looks like it's designed for more torque on fastening and not so much on removing. Just saying, what other reason for the asymm design?
DSLTRK
PHELAN, CA
I think Wakefield's point (and one that was wondering as well), is why the asymmetrical design. I mean that think just looks like it's designed for more torque on fastening and not so much on removing. Just saying, what other reason for the asymm design?
Since it's not a symmetrical fastener, it really reduces driver side-to-side play and of course, cam-out, that would be experienced with a slotted or Phillips.
The design of the Mortorq is more favorable for assembly, engineers probably looked at max torque, tool life and ease of fastener manufacture. This Mortorq design is probably better than Torx for assembly operations when you look at the whole picture.
Wakefield
Arlington VA (but would like to get out to country
I believe that if a fastener drive system is biased for more torque capacity in one direction it should be the removal direction since removal often requires much more torque than was used in assembly.
Unless it is a throw away item that will not be disassembled for repair or maintenance.
