Locking pliers 5”
Long nose pliers
1/4" drive Breaker bar (higher torque than ratchet)
Open end: 10x11, 12x13, 14x15 mm
Box end: 8x10, 12x13, 14x15 mm
Socket: 10, 11, 12, 13, 14, 15mm (6, 7, 8, 9 & 17mm oil plug socket need to go. Get oil plug with smaller head)
Screwdriver: 2 Philips, 2 flats (will replace this with a 1/4" bit holder socket to fit on the breaker bar, screw driver handle is pretty fat! bits are smaller)
Extension long
Extension short
Hex bit set: 2, 2.5, 3, 4, 5, 6, 7, 8, 10 (small sizes need to go)
Tire valve stem tool (not in kit, it is a tire valve cap with stem tool)
Metal saw blade (light weight, very small, never know ...)
Knife (This will go. I have a tiny Swiss Army on my house key keychain. Scissor, knife ...)
Hemostat (not sure but told very useful, small ... well, alright)
VOM (get a flat one from Radio Shack)
The following is a long list of "consumables", list is long but not as bad as it seems. Remember, the quantity is for a ONE time emergency, not for the next 20. Most of the stuff are tiny bits:
Loctite blue
Chemical light stick
Electrical tape
Duct tape (DO NOT CARRY A FULL ROLL ... Duh! )
Electrical wire
Steel solid wire
Steel stranded cable
Fuses
Electrical wire slice connectors
5 minutes epoxy
Sandpaper
Epoxy putty (JB Weld)
Nuts & bolts & washers assortment
Lighter
Isopropyl alcohol (for cleaning surface to be epoxy, water in gas tank)
Nitrite gloves
Waterless hand clean up goo
Pencil & paper
Solder strips
Shrink tubing
WD-40
Radiator leak seal (or black pepper)
Mylar blanket (repair in the rain, stuff in jacket for warmth)
Zip ties
Brake lamp bulb (can remove if there is a redundant LED brake light)
Tail light bulb (can remove if there is a redundant LED brake light)
(Current bike have separate hi beam lo beam bulb ... redundancy ... no spare bulb needed)
Spark plugs x 4 (only if you are going through Mongolia or your bike access to the plugs are extremely easy. Not too many bikes are theses days)
Tire valve stem
Chain lube [long trip]
Gas siphon tube [long trip]
== STORED IN TANK BAG (Absolute minimum carry, even if you skip the tools)
Rain suit
Day-Glo vest
Strobe light (I have had a hi/lo beam bulb died on me, out in the sticks with enough cars zipping by ... ride to the store was scary)
Flash light
Bottle waters
Energy bars
Paper towel
Spare key
Garbage bag
Antacid
Tylenol
Vitamin
Imodium AD
Antiseptic pad
Band-Aid
Breath mint (As you may have noticed, women throw themselves at motorcyclists)
Earplugs (see previous line)
Eyeglasses backup & case
Extra warmth layer
MUST carry ON THE BIKE:
mushroom plug flat kit
Gummy string plug kit (it is small, worth it for back up, I have seen both types failed)
Gutted out cheapo Walmart electric pump (it is quite small after you jettison the case. Beats hand pump that is not much smaller and they are longer)
