Mounting mr heater 80000 btu unit heater
Mc57
Would there be any problem with mounting unit heater at a slight downward angle to get more air blowing down. Planning on mounting in shop near ceiling peak at app. 12ft above floor.
Mc57
Yes it does but want more down with less restrictions from louvers
nadogail
Coronado, CA
Just follow the instructions and add a down ward facing baffles. Unit heaters are designed to be installed and operated in accordance with their instructions. Anything else will be out of compliance.
Ronson25
They had the one at a shop i worked in angle down and it didnt seem to effect it but why risk it if instruction say mount level thats what id do
toyotadriver
I suspect it would work but I personally would not. My 80k Mr. Heater is installed level and I use the louvers to direct the hot air down. I also usually run a fan to help move the warm air off the ceiling and back down to ground level.
TractorJeff
Elkhorn, WI
Mine is mounted close to the 12 foot ceiling in the corner! I have a ceiling fan that moves the air around the rest of the building. I would recommend keeping it level!
