Mounting T5 lights to metal ceiling
c6matt
Greater Detroit (Novi)
I did a search and came up empty and I am sure it has been done. I just ordered 9 8' T5 fixtures
http://www.contractorlighting.com/8...scent-double-channel-strip-120277-p-1475.html
can I screw them directly to the metal ceiling?
Should I put up the ceiling and then worry about cutting the holes for electrical boxes/wiring?
What is the proper way to wire these, do you run the romex right into the fixture? (no box required?)
Any other installation "gotca's" to watch out for?
JohnX14
Boston 'burbs
I checked out your build thread. I would screw through the metal ceiling and into the trusses. You can connect the romex right to the fixture with a connector, but make sure to drill a large enough hole through the skin so that it doesn't cut the romex.
C
c6matt
prefect, thats what I was hoping would work. Popping some screws into the trusses and a 1" hole in the metal will make that job cake!
JohnX14
Boston 'burbs
I'd probably do more like a 1.5" hole saw hole through metal ceiling to allow room for the connector behind the fixture.
JohnX14
Boston 'burbs
Don't overthink it. Put them on 3 switches, but put all the switches in the same location....very likely you will always put all of them on so keep them together. You don't want to be walking to several locations every time you use the garage.
Highbeam
Mt Rainier foothills, WA
I just hate putting all those 1.5" holes in the ceiling which would let all the heat out. It's like leaving a door open. Won't insulation fall down? and if you center the holes over the knockout be sure that you choose a knockout in the fixture that would prevent the big ceiling hole from being visible from below.
JohnX14
Boston 'burbs
He could certainly drill a hole to fit a 1/2" ****** tight and put a connector on the end of the ******. But he can also insulate the penetration.
pattenp
Virginia - USA
My opinion is where NM passes through the metal ceiling the hole would require an insulation bushing or grommet just the same as when NM passes through metal structure members.
JohnX14
Boston 'burbs
I think that is not necessary or required if either a traditional metal romex connector or a T&B 3201 style connector is used. Possibly an argument to be made if a black button type of connector is used. May be a good idea, regardless. With the romex secured to the connector which extends above the plane of the ceiling I don't see the analogy to a metal stud.
pattenp
Virginia - USA
I agree with what you are saying. I was thinking that the NM was passing through the metal ceiling to a fixture that was not flush/surface mounted and the NM would be exposed to the metal cut edges.
Charles (in GA)
50 mi south of Atlanta
It depends on if the lights are mounted on top of the metal's ribs, or running with the ribs and mounted in the valleys. If running across the ribs most of the light fixture will be spaced some distance from the metal, contacting only on the top of the ribs. In that case, the romex would need protection where it passes thru the ceiling sheetmetal, plus the metal or plastic connector in the fixture. If the light is mounted tight with the metal, in the valleys, then a hole large enough for the connector to protrude thru would be needed, and no additional protection would be necessary.
Charles
Aceman
Eastern Oregon
Charles
Thank you for typing this, I was about to post the same thing.
