Mr cool sizing and mounting location
SSStang
Troy Texas
Hello my shop is coming along getting ready to order a mini split
My shop is 30x40x12 in central Texas. About 1 inch closed cell spray foam insulated garage doors. 30 foot side facing south.
Thinking to get the 36k Mr cool unit and a couple wall mounted fans to help move the air around. The garage doors face south. Should I mount the unit on the east side of building about centered?
ford33
Chicago, IL. USA
How about calculating the heat load and getting the right size unit instead of "thinking" about it?
It's a lot of money spent if you get it wrong and you will still feel miserable in the Texas heat.
Fifteen minutes with an online heat load calculator will give you a working number to help you make a decision.
dcg9381
Austin, TX
Load calc is probably best.
For reference, 40x60x16 in Texas, 3-4" of open cell foam, but 3 big 14x14 doors (almost no insulation) - I get by with 2 x 24K units.
My Old Tools
Hamrick Lake, TX
My shop is 30x40x12 with a 6/12 roof, so 22 feet at the peak. I have standard 4" insulation on the walls and another 8" on the roof. 7 windows, 12x12 overhead insulated door, one man door. I put a 36k MrCool in, mounted midway of the 40' wall at 9' up. My outdoor unit is on the northwest side but under a shed roof, so always shaded. After the first 24 hours where it pulled about 10 gallons of moisture out of the shop, it just barely idled to keep it a 75 degrees all summer. I think I might have gotten by with a 24k, but no regrets on the larger unit. Not that much price difference.
Above the 9' level where the unit is mounted, air stratifies and it is quite a bit warmer. Since my loft area is just storage, that works out fine. I used a simple box fan to move the air a bit at floor level, but once the whole shop was cooled down, it really wasn't necessary. This winter I'll probably put a fan in the loft to pull down the warmer air.
SSStang
Troy Texas
Very good point I guess I'm being a cheap ***. Been spending a lot to build this shop, but that's one thing I should spend a little more for the year round comfort.
