Multi meter for inexperienced user
SuzukiGS750EZ
Hey guys. Looking to buy someone a dmm for Christmas. Automotive and simple household use. Auto ranging. Any ideas? I was thinking of looking at esi. Are there any sturdy but sub 80$ fluke?
bmwpowere36m3
My craftsman (probably $50 or less) has worked for the last ten years... automotive diagnosis, electrical, building small electronic circuits, etc. It works well, but doesn't do temp or RMS. However I haven't found a real need for them either yet based on what I use the meter for. I keep telling myself to get a Fluke....
For me, money was better spent on leads, probes, alligator clips, back-probes, etc... Makes using the DMM much, much better.
FigureItOut
Bentonville AR
If I needed a meter in that price range I'd be looking at Klein meters at HD, or Extech Instruments. Each will have several models under $80 that'll meet your needs and more.
One of mine that I've really enjoyed having is my Owon. Consider model B35T+ at $60. It's a true RMS meter, has a 20 amp current rating instead of the typical 10, thermistor, data-logger, and will display on your phone via Bluetooth, which comes in incredibly handy at times.
Sent from my XT1575 using Tapatalk
dogdog
ExTech is not that bad they OEM a lot of Craftsman and maybe other brands..... For home/general uses and price point it is not that bad.... although able to test frequency, capacitance, and PWM, temp comes in handy many of the times.... But it's mostly how you used your tool and your needs.
I have the craftsman for 10+ years now, which is an Extech 430 or 450 older ones now 470.... it's on sales for $99 now. I thought I have something that measures LCR as well but I might have been dreaming on a different dream.
Only Complain is changing the Fuse is a PITA task to take off that casing.
DFB
Southern VT/Western Mass
OMG! :lol_hitti
Take a look at something like a UniTrend 139C
or something in their 61 series
Or any of the 200 series for a clamp meter
Such as a 210E mini
Individual series models have different features based on their letter designations.
You can see them all listed at the UNI-T web page
Units sold under the E Tek name on Amazon are the same but just carry different part #'s
redmondjp
Redmond, WA
Buy an old Fluke 23/77 on Craigslist for $40-50. I've still got mine, purchased new in 1988 and I just used it yesterday.
bdelmar2
I have an esi I bought mainly for the tach. It is autoranging but I don't care for that really.
It was like $200 off the tool truck and I seldom use it, only once in a great while for the tach, or when I need two meters.
Day to day I use a cheaper craftsman, think I paid $30 for it several years ago when the fluke I had died.
Its not autoranging or anything special but it works fine even though somebody managed to hit the screen and bend it back into the case leaving a 1/4" gap at the bottom.
I also have a couple of the cheap hf ones in my vehicles in case of emergency. They seem to work ok, but I very seldom actually use one.
I also have a $20 or so (I think?) one from hf that has the current clamp on it. Handy for around the house. I keep it in my 5 gallon bucket (with bucket organizer) of tools for home repair.
Have a powerprobe at work as well. Its pretty handy except for the cord.
If its something quick I go for the cheap craftsman, if I think its going to take more than a couple minutes I grab the power probe.
If this is somebody younger who shows some interest, I think I'd get the $50 ish craftsman or equivalent, not auto ranging, a logic probe, and a good book on basic electrical testing and theory.
Autoranging is fine if you understand how to use a meter in the first place, but scaling is something you need to understand to get very far in the electrical/electronic world.
We get new guys in the shop and they say they know electrical, but I hand them a standard meter and they are lost. Not good.
A logic probe is basically a test light, but hooks to both power and ground and uses an led instead of a bulb.
You need to know if something is grounded almost as often as hot so being able to do either without swapping is great.
The led doesn't burn out or get broken like regular bulbs tend to, and can test things a regular bulb can't, or not easily. Like injector pulse for example.
The book is the most important of the three item in my opinion. With knowledge you can figure out where a problem is with a variety of tools. Without knowledge and a meter you can look at numbers.
I would look for one with basic theory, Circuits/Series/Parallel, Voltage/Current/Resistance, Load, Current drop, Ohm's Law and that sort of thing. Plus how to read a meter, where and why to test, etc....
EDIT: Ideally not a huge book, or an overly complicated one, something basic and easy that one could keep in a tool box or bucket for quick reference.
Should be able to get all 3 items for around $100.
I don't know of any particularly good books right off hand, but I bet others here on the forum do.
FigureItOut
Bentonville AR
Daniel Sullivan, the inventor of the Load Pro leads, has a book out that's quite good, for future reference. The OP actually recommended it to me quite some time ago and I've really benefited from it.
By the way, thank you for your informative contribution to the thread.
bdelmar2
Hmm... Guess I should start investigating posters before I attempt to reply.
On the other hand even if the OP didn't need my rambling response, perhaps it will be helpful to others with a similar question.
bsaint
Manchester, CT
Flir dm284.
Just kidding.
We have a few cheap meters at work. The extech we have *****. It takes a few seconds to read the correct value. And the leads are super short. Then we have a Klein. That seems to work fine for most applications. You dont need RMS but I would get capacitance for the rare times you have to diagnose a cap start motor on a compressor or hvac unit.
bdelmar2
Capacitance is a great option. I seem to run into the need for that in streaks for some reason.
I talked with an ac repairman last year and he suggested getting a Fieldpiece unit, says its perfect for his type of work.
byoungblood
Berryville, VA
It is nice to have. I had to replace to start cap on my A/C blower fan last year and it was nice to be able to quickly test that it had indeed failed.
Not for everyone, but having a diode check comes in handy when I'm working on some of my electronics projects.
Citation
Indy
Check out the Greenlee DM 200a. It's a Brymen OEM meter. I prefer it over the Fluke 11x meters. They are about $80 on Amazon.
pedrodagr8
This is a solid recommendation. Another option is the Amprobe AM-510. It is a Fluke design, manufactured by Uni-T (like all Chinese made Flukes) and only costs $50.
