I've never had to mess with 220V so am much less familiar compared to 110V. I'm finally wiring up 220V for my TIG. Electrical panel is in the basement and the basement is comprised of a large 4 car garage area together with a separate sheetrock finished room which I use as workshop space. Panel is in this finished room and I have the sheetrock off of the wall with the panel. Welder uses a 50A NEMA 6-50R outlet. I have a 50A breaker wired with 6-2 NM cable to my first NEMA 6-50R outlet in the finished room. I would like to run 6-2 NM cable from this outlet to another outlet in the garage area so that I can weld in either area. I have limited space in my panel so would prefer not to have two homeruns since both outlets will not be used at the same time.
Questions are:
1. I'm unclear if NEC allows more than one 50A outlet per breaker in a residential setting.
2. 6-2 NM cable has black and white conductors. I'm marking the white conductor with red tape. What is a better way of doing this? I'd prefer not to run THHN in conduit.
3. Should I make my runs in 6-3 NM wire for future proofing? I'd prefer not to with the extra cost and bulk of 6-3 NM wire.
Questions are:
