Need 2 things: Thread chaser and Torque angle gauge
Runum
DFW
Not trying to be a smarta_ _, but aren't internal thread chasers called taps? I have always used a tap to clean up internal threads. I have bought several metric taps, mostly at tool supply shops.
bmwpower
From what I've read, they're different. For one, a tap is pointed at the end. A thread chaser is flat (so as to clean the threads all the way to the end of a blind threaded hole). Also, a chaser is designed not to remove any additional metal, which would be a bad thing for obvious reasons.
Runum
DFW
OK I see where you are coming from now. I do agree that chasing a tapped hole with a tap can remove some metal. I have never experienced failure due to this though. I am not sure where you are going to find metric thread chasers. Good luck with your search. :beer:
kartracer55
BMW, I think you have some things confused.
there are three kindsa taps; taper, plug, and bottoming.
A taper tap tapers aabout 6 threads,
A plug tap tapers about 3 threads. The taps you see with points on the end are ususaly made by vermont american and designed for through holes. VA taps are sold under snap on, C-man, and under the VA name.
bottom taps have 1-2 tapered threads at the end. You will want a bottoming tap.
These are all cutting taps, but there are also Thread Forming taps for aluminum and other soft metals. Thread forming taps requiqure different procedures, need a larger hole size, and in general, are a PITA to use
All you need is a bottoming tap. HD and lowes usually dont sell these, so order one from MSC or Enco. They are very handy to have when cleaning or tapping blind holes.
Jim
Runum
DFW
I agree that a bottoming tap would do the trick. Yes, they can remove metal but if used carefully can be used to chase threads successfully. If the blind hole never had a bottoming tap run to the bottom you will definitely remove metal with a bottoming tap. Also be careful about using compressed air when blowing out those blind holes. It's an easy way to get metal in the eye.
