Need help ID'ing this vintage bench grinder
rolenrock
Hi! I'm new to the forum, signing up to be able to ask if any of you can identify this bench grinder and have information to share about its inner workings. I hope to be able to restore it to its former usefulness so I can use it in my shop so I'm going to need to find specs, manual or service manual. I appreciate any help I can receive.
1982fxr
Phoenix
Model number starts with B so maybe a really old Baldor?
Are you sure it's worth your time?
Ole Slewfoot
Freedom, CA
You don't really need any model info, just open it up and measure the bearings.
R
rolenrock
If it is a Cincinnati, where can I find the wiring schematics? Also, it has four wires coming out of it, does that mean it's two speed? It turns over freely, the armature is good and clean, brushes are still intact. My hold-up is figuring out the wiring because the wires are "rotted off" the base of the motor.
Thanks for the help... Deb
Catcher1984
Los Angeles
You probably won’t be able to find the exact wiring schematics but most Cincinnati grinders were for industry using 3 phase 208V, 220V or 440V.
It’s not too hard to figure out but you do need a high amp switch or even better a magnetic starter. You can use wiring diagrams from any 3 phase bench grinder they are all built and wired very similar.
isb cornbinder
I can see this grinder becoming a money pit without a good finish. A new Baldor grinder will cost less that a total restoration. I asked about having and Old GE 5 HP rebuilt at a local motor shop. The cost was nearly double of the cost of a new motor. I bought a new US MOTOR. https://us-electricmotors.com/
for the safety of those who might be operating that grinder, it should have guards. I had a new grind stone explode on my Baldor. The guard save me from harm.
exmaxima1
Midwest
I agree that it is an old Cincinnati grinder. I also agree that it would be a huge waste of time---those old windings, cloth wires, sleeve bearings, and missing parts would be a nightmare. Invest in a better donor grinder for a restoration project.
JHuston
Canton, Ohio
While there's a lot missing to restore it as a grinder, you have the makings of a decent wire wheel or even a buffer ( although the arbors on a dedicated buffer are longer). The biggest issue is to determine what voltage it is wired for; the fact that there a four wires coming out of the motor argues that it may actually be single phase, dual voltage (110/220). Usually grinders of that class are three phase,as has been mentioned, but I would be surprised if they didn't offer a single phase version at one time or another. Either way, those leads look awful and should be replaced.
- James Huston
Seagoer
Goodyear, Az.
Just couldn't pass this old orphan up today. So now another project ahead of me. My drill press is 99 percent finished, with photos to follow. But not now.
Catcher1984
Los Angeles
Is there a sentimental reason you are restoring this? I only ask because that’s a 90’s made in China or Taiwan unit. They work fine but you can find a made in USA grinder for pretty cheap. The craftsman block grinders are built better, durable and plentiful.
Seagoer
Goodyear, Az.
Check the data plate! It's a 1974 and made in the USA.
1982fxr
Phoenix
Ehh, where does it say made in USA, I don't see that part? Just a company name with USA after it isn't the same as the term Made in USA. If that's what it says?
I only see 197 on that tag, which I'd guess January 1997. Can you show closer pics of exactly what you're seeing? To me I'm with catcher1984.
I was looking at that, and assumed they would stamp or write on the last digit.
As is called out in this thread, his was a 1979. I am assuming we could not see the 9 that he could.
Seagoer
Goodyear, Az.
Catcher1984
Los Angeles
That's what it is, 1979.
Sorry I was assuming the year it was made since I’ve handled a lot of bench grinders. But the year doesn’t really matter it’s the quality of them. The plastic on off switch and the steel cast guards are the same ones they used for a number of bench grinders made in China/Taiwan.
Don’t get me wrong though a working machine is better than nothing, it’s just that there are much better options available. Especially if you are planning to restore and use it for a long time.
In the end if you’re happy with it that’s all that really matters!
