Need help picking a fuse
chumley360
OK I've got a Square-D safety switch that I want to use in-between my breaker panel and my compressor motor. It's a D-222-N series E-1 switch. The motor is a 6hp 15amp 240v unit. What type/style/size fuses am I going to need for the switch? I'm pretty sure that I need a slow-blow type but that's about it. Any input would be appreciated, thanks.
StumpjumperDave
Carrollton TX
you can Bussmann FRNR series... or Littlefuse LRNR or Shawmut TR series
all will fit just fine.. and are available from 35 to 60 amps to fit that disconnect
If you want to go any smaller that 35 amps, you will need a reducer kit
