Need help with galvanized 3-1/2 electrical conduit
fred d
Metro Houston Area
Need help with galvanized 3-1/2” electrical conduit
OK this is not really an electrical question.
I have a basketball goal mounted on a 3 1/2 inch piece of galvanized electrical conduit I got from a road construction project.
I have a 10 foot above the ground and approximately five below the ground. My kids are grown and do not use the basketball goal anymore.
I want to add onto the top of the pole and make it into a flagpole.
Would like to reduce the 3-1/2” down to 2” or 1-1/2”and make it 20 foot tall. Trying to find out where I could buy the reducers and 10’ of the reduced size pipe to do this
Aceman
Eastern Oregon
Are you sure it's not 3" conduit? 3" ID, 3.5" OD?
If it is, I'd just use a 3" x 2" bell reducer and thread the 2" in. Done.
You should be able to get galv 2" pipe cheaper than conduit too.
walta
Dutzow Missouri
From a structural point of view I do not think a reducer will stand up the forces needed to extend 10 feet.
I think you will need to connect the 2 inch pipe to the larger pipe at 2 points at least 2 feet apart.
I say fill the large pipe with concrete then drop several feet of the 2 inch in the concrete then slide down the reducer.
Walta
Norcal
The weak point is going to be the threads suspect that they will snap before a bell reducer does.
BillK
Beautiful Southern Maryland
Re: Need help with galvanized 3-1/2” electrical conduit
To answer your question, if it is electrical conduit then an electrical supply house should have what you need. See if you have a Rexel or United Electric near you.
BD1
north side
I would skip the the threaded reducing fittings and use the existing pipe as a sleeve.Determine how far you want the pipe inside, drill a hole thru the 3 and 1/2'', add bolt and nut for a stop to support the pipe that will drop inside.
Buy a threaded steel cap and hole saw the center out for what size you need, say 2'' .
If you don't want to buy cap just shim between the two. You might check for a plumbing rubber fitting like this used in underground.
Marctrees
TX/LA border - Toledo Bend
Post will get more and better answers in "Fab and techniques" sub forum.
For the purposes of this discussion the fact that it is technically Electrical conduit has no relevance.
As said above, strongest end result will be from some method of telescoping the small into the larger pipe.
Marc
