Need help with Reznor heater FE50
Ash0468
Iowa
Hi,
I just moved into a house and it has a Reznor FE50 (from 1991). It’s attached to power and gas lines but I can’t seem to find a thermostat. I’m assuming it’s wired in with the house thermostat which is a “NEST” . Issue is that the heater doesn’t start- no ignition click, no gas blowing , no noise whatsoever. It’s as if it’s dead. I cheched the electrical wiring with a extension cable to make sure it gets power and it’s not a blown fuse. I’m thinking it would be an ignition module issue. It seems to have an electronic ignition system.
Is there a procedure to activate the ignitor. Adding some pictures of the wiring. I talked to the previous owner of the house who said it worked last winter.
Any input on where to start would be very helpful.
Thanks
The Cobbler
so it has power to the unit?
did you try to cross the tstat wires on the unit? remove the stat wires wire & cross the r&w terminals
gas valve is set to sun or whatever?
what is that white wire laying beside the terminal of the module
A
Ash0468
Iowa
Thanks for replying.
Yes the unit has power I have checked.
What are the Tstat wires and how do i cross them?
