Need lightweight floor jack
lbhsbz
Long Beach CA
Pops had a flat on his motor home...the bottle jack wouldn't fit under the frame with a flat tire, so he ran it up on a block of wood and while the bottle jack fit, wouldn't lift it high enough to install an inflated tire. A bunch of blocking/resetting things would have got the job done, but that's a PITA. I'd like 2 ton or so aluminum jack, but with a normal stroke/pump ratio. Those 3 pump "race" jacks would be a ***** to lift a 3500lb corner of a MH. Are there any normal ratio aluminum frame jacks out there?
kctyphoon
Jersey/Staten Island
Just check out Amazon, autozone, harbor freight (although I think all the HF jacks have the rapid pump). I have HF's 2 ton high lift jack, and it lifts my 95 f350 diesel dually extended cab.
