lzicc
I moved my compressor to my new house and got confused on the wiring for the magnetic starter. The compressor will not run. The wire coming from the fuse box comes in through the top and connects to L1 and L2. The wire coming from the motor comes up through the bottom and connect to T1 and T2. The wires coming from the pressure switch comes in from the left of the picture and one wire is connected to L1 and the other wire goes to the lug behind it which I guess is 1. I am pretty sure this is how it was connected. If you look at the wire on the right which is a thin black wire, it came out when I disconnected it and I am not sure where it should go. Right now I have it in the same lug as the one pressure switch wire is in on lug number 1. I'm not even sure what that wire is for. I have a power test light and I get power on L1 and 2 which is obvious, I get power from both of the pressure switch wires, but no power going to the motor wires which are T1 and 2, so it seems like the switch is not engaging. The model number of the switch is 100-NX66H. I believe Allen Bradley is the maker, but I cannot find any info on the net for this switch. Any help would be appreciated. I did let the air out of the tank, so it has nothing to do with the pressure being too high for it to come on.
