Need some help with MC cable
Pudge87
Spartanburg SC
sberry
Brethren, Michigan
You got to snip the flex right, not sure I can splain it here but used boxes of those at one time. I like a pair of red snips really.
sberry
Brethren, Michigan
I know they make a cutter, never used one. Normally,,, use female connector with set screw now. Used some a while back and finally found the anti shorts but dont really use them , can kind off flare it so to speak doesnt cut the wire and done it enough I dont even think about it. Almost automatic.
Gummi Bear
Sunset, Texas
Skip those, they’re a pain in the neck.
Get some saddle clamps, that’s about all we use
Don’t forget to use your red devils (anti-short bushing)
I went to the woods because I wished to live deliberately...
Henry David Thoreau
cybrdyke
USA
Pudge,
That's an MC conduit fitting, not an MC cable fitting.
CD
Bert_
NW Iowa
Yea, those connectors are for 3/8 flex. The kind that doesn't come with wires in it. Get some connectors made for MC. Either the snap in kind or the set screw kind are fine and common.
The anti shorts aren't required for MC cable.
Gummi Bear
Sunset, Texas
Inspectors around here look for them.
They are a part of the UL listed installation. That’s why a baggie of them come with each roll of MC
Henry David Thoreau
Norcal
Henry David Thoreau
The NEC does NOT require them, I use them but they are not required.
alfredeneuman
Fullerton, CA
I phoned Southwire many years ago and they told me although not required because of the mylar jacket (They're required with AC cable, which has paper) they included the bag just as an added degree of protection.
Trying to run some electrical in my new shop and running into an issue. My problem is trying to screw the connector into the sleeve. The leading edge goes in with fairly no problems, but the trailing edge is a nightmare. Is it me, is there a trick or does these connectors just plain ****?
Connector I'm trying to use
https://www.lowes.com/pd/Sigma-Elec...Conduit-Compatible-Conduit-Fitting/1000152481
wrong connector. no wonder youre struggling.
That is for FMC/flexible metal conduit/greenfield
These are what i use
https://www.homedepot.com/p/Snap-2-It-3-8-in-Connectors-5-Pack-38AST-5/100132643
NOT required by NEC code or manufacturer.
This topic is debated multiple times a week in the electrical code discussion groups on facebook but the end result is theyre not required. We even get electricians, who are on the CMPs, that chime in and correct those who think theyre required.
the inspectors are morons and NO theyre not part of the UL listing.
Ya know why southwire includes them? Because they were tired of getting so many phone calls about missing baggies of anti-shorts. Numerous people in my electrical groups have called and this is what they were told.
Theyre not required by anyone but if it gives you the warm fuzzies to use them, then by all means....
interesting. theyve told other people that they were tired of all the phone calls about missing baggies of anti-shorts...
alfredeneuman
Fullerton, CA
We even get electricians who are on the CMPs who chime and correct those who think theyre required.
My call to Southwire was the result of a long retired LA area inspector, also a member of several CMPs and a monthly contributor to ECM magazine's "What's Wrong Here" series claiming that they were required on another forum (I'm a mod there) I made the call about 2003.
Edit: I prefer the saddle connector that snaps into the knockout over the "Shark bite" one that Wylie posted because it covers a wider range of sizes
nadogail
Coronado, CA
Find yourself a Roto Split, I got turned onto one before I retired and found it to be a time saver and it does a neat job. Try an electrical wholesale house. I would be amazed if you saw one in a big box store.
Norcal
The Roto Split models are the best, bought a Klein & not really all that happy with it, was glad to find my Roto Split that was misplaced.
alfredeneuman
Fullerton, CA
I agree.
I bought 2 of them at different times and the both disappeared (were stolen) on big jobs with several trades working at the same time, never to be seen again.
I bought a Greenlee after that and it's a POS compared to the Roto Split.
EDIT: The original maker of the Roto Split, Seatek, has been bought by Southwire and they're still available
P
Pudge87
Spartanburg SC
Once again thanks for the help. I went with the saddle clamps and they made my life so much easier. Also purchased a roto split and its well worth the money. Unfortunately I'll probably never use it again, but hey its garagejournal, we buy tools just because lol. Besides being quick, I also like it for the simple fact you're not putting an unnecessary bend in the wire just to get the jacket to split.
I agree.
Damn i better buy a couple before southwire changes the design and ruins them. Southwire tools are horrible.
I use an Ideal Sir nickless that works great and actually does bend the jacket slightly to get the wires to move away from the blade. It works great
https://idealind.com/shop/35-782.html
P
Pudge87
Spartanburg SC
has anyone tried the US made pliers Southwire has now? I am skeptical.
That is what I picked up from Lowes, it's doing great and feels solid for what it is. Granted, the only thing I have to compare it to is the bend and snip with dykes method. Then I won't be able to give a long term update just because once I'm done with the shop, it'll probably never see the light of day again.
