Just had a 30x40x12 built. it is about 25 ft away from the service meter. There is also a 200A main panel just under the meter on the pole. My plan is to run underground feed from the main panel on a 100Amp breaker underground in conduit to a sub panel inside the shop.
2 mini splits on separate 20 amp breakers and a run of led lights. Not too heavy but maybe a little fluxcore welder at times on the 20 amp and an air compressor.
I need help determining the correct wire to use.
I figure quadruplex and a couple of grounding rods.
Shop is 25 feet from main panel, so about 35-40 ft of wire from breaker to sub panel lugs underground in conduit is my thought.
Calling all professionals!
