New Armorclad Low Temp Garage Epoxy Kits
Armorpoxy
With the colder weather upon us we recently added low temp 100% solids (will cure as low as 40 degrees garage temp) www.armorcladepoxy.com kits. All kits include low temp primer, low temp epoxy, and SPGX 1-part polyurea topcoat.
Remember, it doesn't matter what the temperature is outside, just need to keep the garage at 40 or higher which is easy to do with a small electric heater.
Cure times of course will be longer but the epoxy will cure.
Available in the same sizes as our popular standard Armorclad Kits, Master Kit size up to 600 sq ft and Add On Kit size up to 300 sq ft.
https://armorpoxy.com/products/armorclad-master-kit-up-to-600-sq-ft-with-topcoat-2/
https://armorpoxy.com/products/armorclad-add-kit-300-sq-ft-topcoat-2/
