new garage floor
imaracindad
missouri
i am building a new garage at my home and i would like to install something in the concrete to pull frames and other objects any recommendations would be greatly appreciated. and specs on how to build and install them.
thank you Troy
hitek
Canton, GA
thank you Troy
Not my expertise at all but aren't these things what you would put in the concrete to hook the pulling chains to?
http://www.sjdiscounttools.com/moc3051.html
Hammerdown
The Motor City
imaracindad said:
yes they are i have finally built my own. but i have another question i need the pro and cons on putting plastic under the concrete in the shop?
I am assuming you are referring to a vapor barrier. In my opinion, it is a win/win situation. The costs of the vapor barrier are offset by the protection it can provide. Excess moisture will usually run along the bottom of the barrier and back into the ground table. This will help ensure the long life of well poured concrete. Without a vapor barrier excess moisture can wick through the concrete to the surface. This can inhibit the proper application and adhesion of any coating (epoxy & paint mainly) applied to the concrete. Ecxess moisture can also cause effloressing (sp?), which is a deposit of salts on the surface of the concrete, typified by a white, powdery substance on the surface. This can cause the weakening of the surface and make the area very dusty. A vapor barrier is code where I live, and it just makes good sense. It can save you dollars and cents in the long run as well.
