New Member, RaceDeck Floor
DickC
Hello. Just joined the forum after deciding to order RaceDeck CircleTrac for my 2 car garage floor.
Watched the video, and installation looks straightforward, but I have never worked with this kind of tile before and would appreciate any tips on the best method (short of the expensive shear device they showed) to cut/trim the end tiles to get a smooth finish. Wondering how hard it will be to cut straight, smooth lines that will match up from one tile to the next.
Looking forward to a better looking garage floor.
Thanks, and Aloha from Hawaii.
Armorpoxy
Many of our clients use a circular saw or table saw to cut our GD Series tiles which are similar to Race Deck. They aren't hard to work with or cut.
CombatNinja
Table saw. Set the fence and buzz them through. Make sure you have a sharp blade for neatness.
D
DickC
Thanks for the quick answers! Good forum!
I'm not so confident in my skill with my circular saw for a smooth finish, but I do have a nice neighbor with a table saw, so I guess I can borrow it since that seems like the best. What kind of blade should I use for these tiles (besides sharp)?
Thanks again for the quick help.
396_425
Clovis, NM
I used the blade that came on my Dewalt table saw and it cut the tiles like butter. It was not a fine tooth blade, which I've seen recommended.
D
DickC
Sounds like the tiles will cut easily and blade selection is not very critical.
Thanks!
Shiftless
East Bay SFO
Many people who cut plastic sheets use a fine tooth blade on their table saw or circular saw installing the blade backwards. This trick minimizes chipping which is the big problem cutting brittle plastic.
D
DickC
My RaceDecks are supposed to come next week and I ordered a couple of extra tiles for small areas, so I can do a little testing. RaceDeck said use a plywood blade and cut the tiles upside down, but it sounds like almost anything works.
Thanks for the tips.
James-W
Southeastern Wisconsin
A plywood blade in a table saw works really well. You don't necessarily need to use a large blade, even if the table saw was made for a larger blade. What I am getting at is, if the table saw normally uses a 10 inch blade, you can buy a smaller plywood blade and use it.
D
DickC
....if the table saw normally uses a 10 inch blade, you can buy a smaller plywood blade and use it.
Good tip! I already have a 7 1/4" plywood blade for my SkilSaw, so I could use that with my neighbor's table saw.
Thanks!
matty d
Yolo County, California
Anyone tried a jig-saw? I have only a few pieces to cut for my project - have been putting this off for 2 years. In addition to straight cuts, I have to cut out a circle in the tile for a post. Otherwise the tiles look awesome.
dubber
Canada's Capital
Super easy to cut with a skill or table saw. Obviously the more teeth on the blade the cleaner the cut will be. However in saying that i just used the standard blade that came with my DeWalt skill saw.
