Highbeam
I live in western washington and have a 30x60 pole barn with a 14 foot ceiling mostly built. I am pouring the slab in the next few weeks and have decided to put the radiant tubes in the floor. I have ordered the 2" foam that will lie beneath the 5" slab. The wire mesh will sit above the foam and I will zip tie the tubes to the grid. Beneath it all will of course be a vapor barrier and then compacted gravel. Vertical foam on the edges of the slab with the top cut at a 45 degree angle. The ground temps, down deep, in my area are 50 degrees year round.
I do not intend to hook up the system right away but will only have this one chance to install the tubes. I have worked with pex doing interior plumbing for a bathroom remodel and really like it. I want to use 1/2" pex with several zones. Mostly interested in keeping the shop above freezing when it is into our occasional cold snaps that might drop us into the single digits for a week. The shop doesn't need to be heated like a luxury home. I plan to keep the shop heated to about 50 all the time and then bump it up with a woodstove or forced air furnace when I plan to be out there. It is not a business, just a hobby shop. Still, I want the system to be able to heat the space for a future owner.
The interior will be insulated and sheetrocked.
So my questions are....
1) oxygen barrier or not? Seems to not add much to pex cost but is it really necessary?
2) layout. How far apart for a garage? how close to the edges? what about the doors?
3) length of pex per zone?
4) Any cheap sources for pex?
5) Do you recommend a long sweep electrical 90 sleeve where the pex comes out of the slab?
6) Any very similar examples, project write-ups, etc. that I can copy?
Yes, I'm a novice but also a civil engineer so I can understand technical things.
Thanks
Thanks
.. if you're doing all the work yourself and you know where the pex is you can get tighter
