Hello all,
I am a new poster to the forum, although I have been using this board to learn and research. I think I came across a good deal on a compressor, and I would like to hear some advice on connecting electrical supply to the unit. I will be paying an electrician to do the work, but I don't want to be completely ignorant on what he is doing and have a few things ready to make terminations. The compressor is made by Emglo, model J5A-60V. According to the Jenny tech rep, it was built in March 2000. Some notable specs he pointed out to me... 4 cylinder single stage splash lubricated pump, 23 CFM @ 125 PSI, Marathon Electric 5hp motor (1735 rpm), and 60 gallon tank. I spoke with him before purchasing and he assured me it was a solid unit. To my eyes, the compressor looks pretty good for its age, especially the electrical components. I sure hope it runs, as I didn't get to hear it run before buying. I will change the oil (30 wt. motor oil?) and the fan belts before running for the first time. Open to suggestions for other preventative maintenance items to perform. By the way, it will be used for miscellaneous shop tools, a small sand blasting cabinet being the largest consumer.
I will be running MC cable across my shop to supply the power, roughly 60-70 feet, but I do not know what gauge wire to use. Also, the whip coming off the compressor where it was hooked up before only has two wires coming out of it. I though 220v would require 3? This should reveal how ignorant I am. I would like to get the MC cable run and sitting in place before the electrician arrives. I imagine I'll be needing a disconnect switch (suggestions??)to turn the compressor on/off, and would like to have this all mounted as well. I see lots of talk about magnetic starters... do I need to worry about one of these? Looking forward to hearing comments and criticisms. I will attempt to attach pictures below.
has NOTHING to do with how loud or quiet a pump is. The main factor is how many RPM a pump turns, the slower, the quieter. The second is the intake air silencer, most of the sound a pump makes is generated by the valves opening and closing. The better the intake silencer, the quieter the pump...same as muffler on an engine.
