Nielsen interchangeable disc system group buy
PT Doc
I thought I would post this here as well. This disc system works really well for metal and wood as well.
Since there has been very positive feedback on the Nielsen interchangeable disk system, I thought I would put together a group buy.
I have spoken with Wayne Coe (US distributor) about this and these are the details.
http://www.nielsendesigndiscgrinder.com/Welcome.html
The deal is as follows:If there is a purchase of a minimum of 10 hubs with two disks per each hub we will be able to include an extra thin disk at no charge, plus shipping of $12.35 and insurance of $9.25 CONUS. Please go to the site to read up on the various plates. The hub is $254, flat plate is $54, 1 degree bevel plate is $67 and the modified flat plate is $60. Pick and choose what you want. The thin flat disk that is the free disc offered with the sale of a minimum of 10 hubs and 20 disks (either standard flat, modified flat or 1 degree beveled) is half the thickness of the standard flat disk. There is a 1/8” thick center indexing extension on the hub so with the thin flat disk this extension would be sticking out beyond the disk. Any disk should be used with a pad between the disk and the abrasive paper to allow a smoother surface and to prevent uneven wear on the disk. Wayne sells such a self adhesive material for $5.00 per disk. Some people use automotive gasket material or sheet cork. This disc is thin and will allow you to get into tighter places.
For each motor, VFD, wiring kit, Wayne will include a free VFD mounting bracket with a minimum of 5 units. Wayne offers free shipping CONUS on the motors and VFDs. The VFD for a 1 hp motor is $350.00 with the reversing switch. The 1 hp motor is $239.50 for the rolled steel motor. If ordering the motor for$239.50, then the wiring kit is $45.00. So the shipping and insurance is the same (CONUS ONLY) if you get a motor and disc or just the Interchangeable Disk System.
Payment would be made to Wayne and shipment will be from Wayne to you directly.
If you are interested, please email me so i have a running list. Thanks.
