NM push in connectors vs clamps... Interchangeable?
mike93lx
Richmond, VA
I have always used NM clamps when wiring up boxes and fixtures, but was wondering if I can use the plastic push in connectors interchangeably. What's a best practice and what's acceptable?
rlitman
Long Island
The plastic push in connectors meet code for NM, but I don't care for them, or the way that they don't do a good job of securing the wires. Be sure to staple right near the box if you use them.
u2slow
BC
IMO, there's a time and place for them. They're very handy for fished-in cable, and quick or temporary work. They can also be snapped on mid-span.
The rest of the time I use set-screw metallic ones.
Terry D
St. Louis, MO.
We use all plastic ones. If you get good quality ones, you wont have a problem. some are actually rated for 2 conductors. Metal ones still have their purpose, like fishing a wire down to a recessed panel. your able to attach it on the wire without the lock nut, pull the end through a knockout and put the locknut on.
