ketas47
I am done hooking up my boiler(45000 btu non condensing), plumbed boiler outlet to pressure/temp gauge to expansion tank to air elimanator to relief valve to hand valve to 3 speed pump to hand valve to 4 valve manifold(4 loops 230'long each) to floor to return manifold to strainer to pressure/temp gauge to fill valve to inlet to boiler.I am waiting for electrician to hook-up pump to boiler then thermostat.
Garage is 26'x38 2x6 walls 10 ceiling fully insulated
I want to heat it to about 50*
My goal is to have outlet water from boiler @ 120-125 degrees and inlet @ 110 degrees.
I know water should be at 140 returning to boiler or else to it can shorten your boiler life and cost more money for gas.
But I am going to try it and see if it really will cost more.
I dont have to pay for expensive condensating boiler and relays. Plus the extra expenses with technical repairs if needed. Trying to keep it simple , no mixing valve/pump, no relays, etc.
I asked people how much more it will cost to run or how much life it will take off the boilers life and cant get an answer.
If I can keep the water difference 10*-15* I cant believe I would get that much condensate
I paid $150 for boiler and bought everything else @ menards so I dont have much money invested.
What do you think?
I will try this system and then really know if it is efficient or not.
Thanks Live and learn
What do you think?
