Offset Handle Ratchets
The Critic
CA
They appear to be an inverse of the old-school “spark plug ratchet.”
Truthfully, I did not know this existed. I can see this design being useful for some repairs. Does anyone use this style of ratchet on a regular basis?
mikey03
The ones I seen got 45 degree handles and honestly idk what there used for so if someone can post a pic of a fastener in some weird access spot that this is the right tool I’d love to see that please
impactims
Just buy one from snap on. Sooner or later you will find a need for it.
Anyone that uses tools knows that often times one can technically get by without a certain specialty tool, but the specialty tool can make things go much easier thus it is better to have the specialty tool. I know I have plenty of tools that I could get by without, but life would be harder without them.
T
The Critic
CA
64C10
Globe, Az
I’ve got a Diehard offset (fixed head) I saw at Advance Auto a couple years ago and thought “that looks really handy”…… to date it has never been used. But, deep down I know that one day it will be the greatest thing since sliced bread.
ohhimark
detroit
Does anybody other than Snap On make one?
I bought a SK palm control ratchet from Sears with that kind of offset. It would've been great if it worked, but it had the same issues most palm control ratchets were known for, and I never found the sweet spot adjusting it. SK had me send it back for a flex head bent handle ratchet, which works fine. I got a 1/4" palm control ratchet at the same time and it has worked flawlessly.
Hohn
Diesel Central, Indiana
Well yes. We could get by with no internal plumbing, no heat but a fire and no air conditioning. At least our ancestors could.
But me, I'm no heathen. I buy specialty tools. Especially any tool that is the difference between me doing it DiY or having to hire out.
I have an oscillating multitool I've used maybe three times. Cordless, works with my battery system. Needed to to cut out a shower drain that was leaking at the pan but hard-locked in by mineral deposits. Tool cost $100. Hiring a plumber would have cost triple that. If I never touch it again, I'm still money ahead.
Rabid Badger
Huh. Looking at the ratchet in the OP is making me wonder why that isn't the default design for short-handle flex heads. It seems like that would save a lot of busted knuckles.
mikey03
If it has a flex head why can’t you just flex the handle to get clearance for your knuckles? I’m sure there’s some reason for these but I can’t visualize it
Kurt4440
Western New York
Correct, flex heads are literally more flexible. 😁
If the ratchet doesn't have a flex head, offset handles can provide additional clearance for your hand, especially with shallow sockets.
There are plenty of cheap offset handle ratchets, if you want to try one before spending Snap-on money.
mreisner
North of Detroit
I've actually got that one and it's a darn handy little ratchet. The back drag isn't terrible and it definitely has served it's purpose.
Wamsutta
Amarillo, Texas
They appear to have made some updates to the 100 tooth so it is getting less junky.
There is absolutely nothing wrong with the 80 tooth design. They wasted all that money on research and development for a 100 tooth ratchet that's no where near as smooth as the 80 tooth; plus the thing goes into neutral. Ratchets aren't supposed to go into neutral. And after all that, they're still lagging behind in the tooth count wars. Cornwell has a 120 tooth ratchet now. I would've been way more impressed if Snap-on said we're sticking with our 80 tooth and the hell with everybody else.
