ToolmanTom
I have a 91 Toyota MR2 2.2L non Turbo, After I changed the Timing belt it started "Hunting" not all the time Just when it is warm, and not all the time. when I engage the clutch so it drags a little it goes away. I have adjusted the Ignition timing back and forth so it feels like the most torque, but it is still "hunting" checked for vacuum leaks, loose wires, adjusted the Idle Air Valve and nothing changes, not even the Idle speed...? it seems to be idling around 1400 RPM. that seems high to me. if the ignition timing is adjusted and lowers the RPM's it has no power. Any suggestions would be appreciated.
