Old rooftop HVAC unit
Diddly
Kanata
My soon to be converted poolhouse turned garage is presently heated by an older Lennox heating/cooling unit, it presently works very well but am trying to guage how inneffecient it may be. Trying to justify tearing it out now and installing a hanging forced air or tube type overhead radiant heat vs. just running whats there until a major breakdown occurs. Near as I can tell by the serial number/model number it is a 1978, 2.5ton A/C unit (240v) and 90,000BTU gas heating unit. Model # is GCS4-311-90a-4p. The building is 36x48 with a 15' vaulted ceiling, 1 wall is R20 with triple pane sealed windows, roof is r20 , and 3 walls are cinderblock filled with vermiculite (non asbestos). Anyone have any experience with these? I am planning on using mostly for heat with little to no A/C use.
JimVonBaden
Northern Virginia
If just for heat I would leave it until it broke unless it will be a major pain for your renovation, or to remove it later. Heat only systems are fairly cheap, and somewhat more efficient these days. It is the AC side where bigh changes in efficiency have come recently.
Jim :cool:
jimp
oo
Looks like heater is 75%. I use a similar unit to heat and cool my shop. Since they are outside they can not allow the flue gas to condence and freeze in the heatexchanger, so about 81% is the maximum.
