OSB Subfloor - Final Covering
duneslider
Riverton, Utah
What do you do on the floor? Just storage? OSB mostly starts to do this do to moisture. I have just painted it with good results in areas that aren't high traffic. If you have higher traffic needs then maybe a covering makes sense but paint has worked well for me.
benjy
Houston, TX
Painting or sealing sounds like the right idea even if you cover it. If it starts getting traffic, maybe a roll of cheap vinyl flooring would work unless you need the look of the stuff in the link.
I bought quite a bit of cheap luan underlayment & used in my mezzanine over really crappy plywood.
duneslider
Riverton, Utah
Just storage. Almost everything is in plastic bins. Then foot traffic from me two or three times a week.
I don't think it's moisture, I live in a dry climate and no roof leaks.
I think it's just an expected amount of splintering, but I didn't know if it was something I should get in front of.
I have had osb as shelving and such for 15 years and it occasionally has "splinters" that come off or peel off but not big deal. I have some that is painted and it has held up better. Mostly I don't care and find it holds up just fine.
By moisture I was also just referencing humidity. It doesn't sound to me like what is happening to yours is a big deal though. I have a loft area with totes and such like you describe and it is doing just fine. I originally thought I would paint it but got lazy and haven't bothered.
CSRPenFab
Meridian Idaho
At my prior house, I had a "Tuff Shed" with an OSB floor. They had applied some sort of coating to it and it held up just fine. It was like a thick "deck paint" that had a bit of grit in it. You might call your local Tuff Shed place and see if they'll tell you what they use.
Jayman17
Seattle, Wa
How about applying a water based polyurethane floor finish? Will quickly roll on and dry quick too. I’ll bet 2 coats will do.
Jay
