BHR4CE1
Hey Guys,
I am in the planning stages of the final part of my home remodel…the back terraces. Since I already have a few of these wall mounted gas heaters (see link below) in the alcoves in my front courtyard, I had decided to use multiples of them placed in certain areas where I thought a little warmth might come in handy in the “colder” months here in Southern California.
http://www.patioheatingplus.com/S34SS-Sunpak-p/s34ss.htm
After talking to a few people, it seems that these heaters might not be able to keep things toasty all by themselves since the area above is completely open, and since heat rises…most of the warmth will just float away. I was thinking about having these areas fitted with some sort of radiant heating under the concrete to aid in the warming up process.
The current surface out there is Mexican tile on a concrete slab, which will all be removed. The new outdoor flooring will be stamped concrete, so the slab will already be getting ripped up for the installation of chases installed for various electrical, low voltage, automation, network and plumbing lines that will be running around back there. This should make installing radiant heating system a lot easier.
I know ZERO about radiant heating, and am very open to suggestions and would love to hear your opinions on what system to use. I tend to always want the best I can get…usually looking at more “industrial” or “commercial” products for my home when available. I am not necessarily looking for an economy solution, but rather a proven, high performance system that I can use all the time and never have to worry about failure. I would say that the area I will want to heat would be approximately 20’X35’ overall.
Thank you in advance.
