Overhead door cables
tatra
pirate contest city
Got to replace some frayed cables on a friends door. Is there a specific type for this kind of application . Single bay 10 wide 12 high insulated with 1/8” cable . I’ve installed and tuned but has been 20 years since I had to deal with one . Never had to replace a cable before because either new installation or they were good condition , tia.
dw1
Ky
If you can get the cables off, measure them, you can find them pre made online pretty cheap
Hot Rod Grampa
Near Cooperstown New York
Most important is they are the exact same length as the old ones. 1/8" cable has 2 common options. Coarse strand or fine. The fine is more flexible and conforms to the drum easier. Would be my choice.
T
tatra
pirate contest city
So not an aircraft cable grade or anything specific ? Buddy said any cable the correct size will do . Always thought oh door cables were specific grade or type ?
kbs2244
No specification that I know of.
When you think about it, it is a pretty low stress application.
jstroede
Kansas City
Standard 7x7 or 7x19 cable will be fine. The ends and the length are the important part. Make sure that the cable is 1/8" because 5/32" cable is commonly used is overhead doors as well. With a door that size, it will be torsion spring, so you will need to remove the tension in order to do that. If you do that, you will need to count the number of turns on the springs in order to rewind them correctly.
John
Git
S Cal
$9 from Home Depot? (they are just 1/8" galvanized steel - nothing special)
13' cables for $27
https://www.amazon.com/dp/B00WBQU7BS/?tag=atomicindus08-20
14' cables for $22
https://www.mcoverheaddoorparts.com/14-Garage-Door-Cables-torsion-spring-p/gdc14-t.htm
T
tatra
pirate contest city
Price isn’t a concern at all . And I do know about the torsion spring aspect of the job . Used a Vernier for measurement and got 0.128 on dial. Hadn’t even thought of HD or Lowe’s . Like I said have always just worked with what was already installed or supplied new . Looks pretty simple so thanks guys . Figured it wasn’t anything special but alys good to check in here .
