I just had a drywalling crew finish up my drywall install.
Wanted to know the steps needed to prep for primer/paint.
I know inside the house I tack-cloth the walls, just wondering what's needed in a huge space like a garage (it would be $$ in tack-cloths for sure!).
Any tips/tricks for prepping fresh drywall for paint?
FYI I plan on using the Kilz premium due to the mold/mildew retarder...living near the DC swamp land, I figure it is worth the extra cost.
Thanks for any ideas,
There can be more than one way to prep drywall for painting depending on the level of finish you want and the level of finish the drywall finisher left you with. . From your post you tacked clothed your interior house walls, which is defiantly overkill, you I assume are a high detail individual looking for a top finish. I have over 25 years as a painting contractor completing both upper level residential and production commercial jobs, here are my suggestions for a gloss finish for high light reflection.
The first step is cleaning, while you do not need to tack cloth you do need to vacuum and sweep very well. Make sure you get all corners and electrical outlet openings. If you want to take it one step further use a leaf blower or wipe the walls down with a damp towel over a push broom.
I have used a lot of drywall primers and my main choice has been PPG 6-2 Drywall sealer. Aside from giving a good sealed surface it blends the paper and mud seams very well. There are additives you can buy for mildew.
I have not used Kilz for over 20 years and then it was the fast dry oil base original product, so I am not familiar with the product you are using. The main key is to make sure you put enough product on the wall as you are rolling it, if you spray make sure you back roll. If you have a fast dry product and you skimp on the first application it will dry with a rough texture. If you are planing on a semigloss or gloss finish you may want to consider two coats. The second coat will take approx half the material and about half the time as the first coat.
If cost is a factor, two coats of cheap flat paint will work. However, it will always be dirty, you can't wash it and if you want to repaint with a sheened paint you will have to prime. If you are trying to cut cost use two coats of a primer in white and then down the line you can finish with the desired material.
