Pass through socket holder?
RichWentFishing
I have a set of craftsman pass through sockets. Love them. However the blow mold case has taken a beating throughout the years and I'm looking for a socket strip to hold all the sockets. Does such a creature exist?
gdocktor3
Connecticut
I haven't seen any. One idea is to get some wooden dowels or something and make your own. Or you can glue the corresponding nut to each socket on to something and use that.
Loscaldazar
I haven't made one yet, but I've bought the material for it. It'll be July before I will have time to actually make it though, so I'll describe what I'm planning in words instead of pictures.
I got 12 feet of 5/16 Cold Rolled steel round bar for the "1/4 drive equivalent" pass through sockets and 12 feet of 9/16 cold rolled steel round bar for the "3/8 drive equivalent" pass through sockets. I was going to slice the round bar into small studs (probably 1/2" lengths, maybe smaller for the little sockets), and weld these studs to a piece of flat bar (bought 12 feet of 1/8" by 1"). You could do the same out of wood and dowels as said above, but then you wouldn't get to have the fun of playing with dry cut metal saws and welders :p
Total cost for the metal was $15, and I WAY WAY over bought the amount of metal I need (12 foot lengths is the stock length the local steel yard sells, so it was cheaper to buy the stock length, rather than pay $2-$3 a cut and get the shorter amount I needed).
I contemplated using the correct sized nut and welding those to the flat piece of steel, but realized that would be super expensive (unless you already have a complete stock of nuts from 4MM to 16MM or 8MM to 20MM, plus whatever the fractional sizes are), and they probably would stay on nearly as well as if they had a peg through them.
R
RichWentFishing
Yeah looks like there isn't anything commercially available. I was hoping for something that's portable so I can throw it in a bag and go.
djcslice
I would also recommend the magnetic socket holders. They should be able to hold all of your sockets since the OD is similar to standard sockets.
AndreaW
Texas
I finally found a pass-thru socket organizer/storage solution that I'm happy with. Pictured below is my minimal "go" toolbox with a Crescent X6 Pass-Thru Adjustable Wrench Set. To keep the sockets organized and make sure they stay put, I have an 8" Magrail with 1/2" Studs from Vim Tools. The rail is stuck (magnetically) to the bottom of the toolbox and the sockets are stuck (magnetically) to the rail. You slide the studs into the rail's channel to position them where you want and then screw them down so they stay fixed in place, which allows custom spacing between sockets. The magnet is strong enough to keep everything secure and sockets come off the rail with ease when needed.
