Hi all,
New home owner here, hoping to gain some insight on doing a DIY garage floor system. I have a ~650 SQFT 3 car garage with relatively small stem walls that I'd also like to coat.
A little bit about what I have planned: I would like a full-flake system in a neutral color (gray or tan) with a polyurea or polyaspartic clear coat with some aggregate for slippage.
I am trying to price this for less than $1500, all inclusive. I have a new construction home and the concrete has been cured, is older than 3 months, and has not seen any vehicle traffic yet. I plan on renting a diamond grinder and using a finer grit as I don't need to remove any stains, just open up the concrete a little to make it more porous.
The system I thought I wanted to install was a colored base coat epoxy with full flake coverage, but realizing if I wanted a full flake system, the color of whats underneath probably wouldn't matter a whole lot.
The insight I'm looking to gain is:
And lastly, does anyone see any issue with the proposed system? I feel this setup would be pretty basic, but from what I understand, would be a decent system.
Thanks, and I look forward to hearing from you guys.
- What is a "good" base material to use for a coating between the concrete and the flakes? I don't believe it would need a superior abrasion rating, but from my understanding it just needs to act as a good chemical and water barrier.
- Is there a specific material and size of chip/flake/broadcast that I should avoid or move towards? From my albeit limited research, I have only seen vinyl chips/flakes. Does the material even matter? I plan on using at least 1/8" chips and leaning towards 1/4".
- What is a reputable polyurea/polyaspartic formula to use for the topcoat? I have researched and so far selected GhostShield Polyaspartic 745, NOHR-S Polyurea (Apparently very friendly to DIY with Pot Life) and Armorpoxy SPGX (One Component, like NOHR-S is alluring for a first-time DIYer)
