Plumbing questions.
1Garageman
Columbus, Ohio
Hello everyone and thanks in advance! We have two 50 gallon water tanks in our house. It is a 3,600 house with three showers and five toilets. I think we could get by with one nice newer water tank. One of the tanks just ruptured open over the weekend. I have it unhooked and drained and we our using just one tank. And we seem to be getting along ok with just one water tank. However I am thinking of replacing it with a newer tank. I am worried that it is also going to start leaking, or blowing open like its twin tank did.
1.Could you recommend some electric water heaters?
2. What shut off valves do you recommend? We currently have plastic crappy valves that need replaced!
3. Are the Sharkbite valves any good??
Thanks for your help, and yes the power is off to the wires you see.
PCustoms
VT
Why are your toilets hooked to the water heaters?
You'll need to determine the circuit capacity, nothing is shown in the pictures that tells us how much power is available.
If the tank did indeed split you may have other issues going on, as that's a very unusual failure.
Calling a plumber might be in your best interest
1Garageman
Columbus, Ohio
The toilets are not hooked up to the water heaters. Not sure how you are imagining that??
They are on standard 30 amp circuits
mike93lx
Richmond, VA
Cpvc is terrible. I'd be looking to change out as much of that as possible with this project.
Not sure if Sharkbite are OK? Call a plumber.
jlv03
SE IA
If you are sticking with electric, I'd seriously consider replacing both tanks with as large of a heat pump water heater (HPWH) as possible - 75 gallons or so.
duneslider
Riverton, Utah
You don't say how many people are in the house. I know for a fact that one 50gallon won't keep up with my family of 7 but we have had zero issues with 2 50 gallon tanks. We are on NG but if I was on electric I would for sure be looking at a heatpump water heater for sure.
dcg9381
Austin, TX
It seems that you have 2 x 50 gallon water heaters, not water tanks.
Sure you can move to a single unit. A rupture is pretty unusual. Are you on well water?
There are a number of things that need to be addressed in that install, I'd be calling a plumber... Like expansion tanks.
Just use brass ball valves.
The brass ones, but in general Sharkbite is a "retrofit" deal. I'd be brass valves with PEX fittings.
HoosierBuddy
Southern Indiana
If your house has natural gas, I'd switch over to a single 40 or 50 gallon NG water heater. The recovery on our home's 40 gallon NG water heater is quick enough that we never run out of hot water. (5 people 3 baths). NG water heaters typically recover 30-45 gallons per hour. Electric water heaters (standard) are less than half of that. Plus, NG water heaters cost about 1/3 the amount to operate vs a standard electric.
If I was stuck using an electric water heater (pinches nose)...I'd do as jv013 suggests and look into a heat pump style unit of about 75 gallons. It would have a still lower recovery rate, but at least you'd be saving money during those short tepid showers.
dcg9381
Austin, TX
These do a secondary job of "cooling" the area where the water heater is. So sometimes that's an advantage and sometimes it's not. IE, they'd be great in a Texas home in an attic... Or perhaps in a basement where you're taking advantage of some of the geothermal heat transfer. They are more expensive and generally recover slower as mentioned.
I like the idea of having 2 water heaters, you simply shut one down when you don't need the capacity. But I'm not sure the expense and double the failure rate justify it.
HoosierBuddy
Southern Indiana
If you replace the tank's anode on a regular basis, it shouldn't ever fail. Most people just don't.
I never did when I could buy a new NG water heater for $150. Now that they are pushing $1000, I damn sure do.
1Garageman
Columbus, Ohio
We could switch to gas tanks. There is the main gas line that comes into the house right above it and then splits off into three different areas and has two spots open on the spiller that are sealed off.
PCustoms
VT
Keep in mind the venting requirements
mike93lx
Richmond, VA
Having gas and heating with resistive electric is wild. I'd move over if you can vent and would go with an on demand if you can deal with the condensate
fitter30
Peace Valley,mo
Would recommend repiping the drops when you get your new heater to get rid of the dead legs going to the abandoned heater. If going back with two heaters recommend piping first in last out ( reverse return)/instead of equal pipe lengths like it is now. Like the two Fs.
FℲ
PCustoms
VT
With gas available I'd check the feed size and strongly consider an on-demand.
Easier to vent, arguably better.
PoorUB
Fargo, ND
One 40 or 50 gallon gas will give you more gallons per hour of hot water then the two electrics you had. On demand is nice, but expensive to install. Either way with gas you will need to vent it outside and you need to be aware of any issues with windows, how close is the gas meter or any fresh air intakes.
PoorUB
Fargo, ND
How so?
Sounds like he has gas* available, no venting. PVC vent is a lot easier the run then other options.
*Need to verify demand/supply
You need to vent it whether it is PVC or metal, It can still be hard to do in many situations although PVC would be easier. Sure you can vent it through the sill, but if there is a fresh air intake, gas meter, or a low window it may not be possible. A power vent 50 gallon would work too.
Generally the on demand just cost more than other choices, plus you need a good gas supply 200,000 BTU for one in a family situation. I have installed them and had to re-gas pipe what was there and the utility had to put in a larger gas meter.
The OP might have electric because gas is virtually impossible. I have put 90% furnaces in homes and had just one way out and that was almost impossible.
75gmck25
Alexandria, VA
I used a 50 gal power vent gas HWH and it required 2" PVC for the exhaust. I just ran the vent out the sidewall of the house. The power vent fan is a little loud if you are near it in the basement, but you can't hear it anywhere else in the house.
