I have an existing 24x36 pole barn I’d like to be able to throw some heat into during the Iowa winters. It’ll be electric heat (30,000 BTU). Won’t be heated all the time, just when I’m out messing around. There’s no ridge vent or soffit vents. I don’t want to put in a ceiling. Spray foam is out of my budget. Is fiberglass rolls not a good idea? I was thinking about running some 2x6 up the roof deck under the perlins and adding some unfaced R21. This will give me a 3.5” air gap between insulation and steel. Then follow up with some white 12mil plastic as a vapor barrier. I’d probably do something similar to the walls - frame in some 2x4s and insulate with R13. Anyone have experience with this? I don’t want to go through the trouble and money, and have the insulation get ruined after a few years. Thanks!
