Power Indicator Light
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
I have my generator fully functional and will be utilizing a manual transfer switch.
My question is can I mount a small light on my meter panel to indicate when line power is restored?
I do own this panel it is a meter panel / transfer switch I installed for the generator hook up.
ishiboo
Oshkosh, WI
Not sure what you intend to do with the first component, you only need the second link (the lamp) and perhaps a fuse/fuse holder. I would go with a LED indicator, your issue is that you have no means of shutting off utility power to replace the bulb/etc.
offroadsteve
Hampton, VA
Has the transfer switch already been installed, or will be installed?
You'd already have the power off to do the transfer switch. Otherwise, you need a way to isolate line power to the transfer switch so you can wire up your indicator light. Main breaker upstream of transfer switch?
Mustang51js
Haskell nj
What's your set up, is it a whole house or partial, I've done the second link you have to one of my friends house,but it's not legal because there's no breaker on it, but the wire is small enough that if anything happened it would melt quick and break off.
N
NWOhioChevyGuy
I like the Reliance PowerBack unit, but my connection would be above the meter on the pole outside.
Any experience in extending the leads on this unit? I will need to mount it inside out of the weather and run the leads through my conduit to the meter panel.
Mustang51js
Haskell nj
It's kind of a gray area because it would be in the meter pan and your not suppose to run anything else in there. But since that one thing looks like it just detects current without being attached I don't think it will be a big issue.
95blklsc
N
NWOhioChevyGuy
I wonder if one could modify the alarm mentioned above to drive a light instead of the buzzer.
This I could mount on a 3R box outside on the pole with a simple LED indicator lamp and a weather tight switch.
This I may have to dig into further. :)
N
NWOhioChevyGuy
My transfer switch and meter socket panel is one and the same.
I will have to get the unit and see how it installs before I can answer that.
Ordered one this afternoon, will provide a response once tested.
N
NWOhioChevyGuy
Received the PowerBack unit today,, I should be able to install the sensor wire on the feed below the meter where it feeds my manual disconnect.
Next to figure out what light and power I have to use.
Since the unit is designed to be installed indoors and is not weather rated I will have to install it inside the panel, and fire a light mounted in the panel side.
I should be able to steel power off the connection for the buzzer as it is quite loud and i don't think the small LED will draw enough to bother the circuit.
Got some testing to do.
davidlee
Pensacola, Fl
I know you said a light and I was thinking of the same thing a while back but our power company installed a new smart meter (digital) so when the power is out the meter is blank and when the power is restored the meter comes back to life. My problem was solved with no help from me.
Ross/Kzoo
Richland Mi.
#0 years ago I made a suggestion to the power company that I worked 38 years for to have 2 green LED lights in the meter to indicate incoming power. They didn't like the idea.
Westly
U.S.A.
N
NWOhioChevyGuy
If it was me only, my options would be much easier and open.
But I need to have this all set up so my wife can easily switch it on.
I have an LED strip coming that will be mounted on the exterior of the box driven by the power monitor linked to above. I am leaving the buzzer installed also so I will have a visual (from house) and audible indicator outside.
The lite meter would be nice but in the sticks here I don't see those coming soon.
The mean fish
My meter can, generator transfer switch and outdoor primary panel is on a pole about 20' away from my house next to my water well house and generator pad. I installed 2 green 120V LEDs on the shore power input side of the transfer switch and 2 more yellow LEDs on the generator input side of the transfer switch each with their own small fuse inline. I mounted them in the side of my transfer switch housing in a place where I can see them from the house out the kitchen window. They look a lot like what you posted from Grainger back in post #1.
With a simple glance out the window I can see if I'm getting power on both hot legs from the transformer on the pole or I can see if I'm getting power from both hot legs of the generator.
