As antolod said it should have a battery backup. I wouldn't recommend unplugging the system, because the ones I worked on and installed sent a signal to the call center and then you might get a call asking if everything is all right. If you have a subscription with a security company they will monitor your battery also, and they will tell you when it goes bad.
